prince_punia
4 years agoFitter Error in Arria 10, while placing IOPLL and LVDS SERDES in a single bank
Hi, I am using Arria 10 board: 10AX048E4F29M3SG
I am instantiating one IOPLL instance and 7 LVDS_SERDES instances (for RX) (4 channels per instance) in a single IOBANK (3C)
While doing so, I am ...
Ash_R_Altera
4 years agoHi,
Can you let Fitter assign the pin locations on it own? Remove any pin assignments allocated by you. See where the tool places them. May be there is a pin which is restricted due to SERDES pins.
