madhan_m
4 years agofailed loading rbf in Agilex DK-SI-AGF014EA board
getting error while loading rbf in Agilex DK-SI-AGF014EA board
SOCFPGA_AGILEX # load mmc 0:1 $loadaddr 1.core.rbf 1937408 bytes read in 91 ms (20.3 MiB/s) SOCFPGA_AGILEX # fpga load 0 $loadaddr ...
tehjingy_Altera
4 years agoHi Madham_m
You do not need to manually load the rbf files.
It will be loaded by the SDM before booting into UBoot.
You could refer to the link below for when the rbf files are loaded during the bootflow.
https://www.intel.com/content/www/us/en/docs/programmable/683389/21-4/introduction.html
HPS First Mode : Chapter 3.1
FPGA First Mode : Chapter 2.1
I believe the command that you used are command to load the Linux Kernel Image during uboot.
Could you share where did you get the command to load the rbf file from uboot?
Jingyang, Teh
