Example design: Agilex I-series devkit not detected by lspci (stuck in S_CFG_LINKWD_START)
- 4 years ago
I found the issue.
The default position for the SW3 is defined in the UG as OFF/ON/ON/OFF, to use the refclk from the connector.
The board was received with OFF/OFF/OFF/OFF, to use the on-board refclk.
I set the SW3 as documented and it's now enumerated by the bios and seen in lspci.
Why it doesn't work using the on-board refclks?
Devkit: DK-DEV-AGI027RES
Serial number: AGIPCIE8000248
I receive a new update on R-tile bug issue, it might be one of the root causes of your problem.
Please refer the link below, download and install the patch, the problem shall fixed in future release
https://www.intel.com/content/www/us/en/support/programmable/articles/000090874.html
Let me know if this help, Looking forward to hear back from you
Wincent_C_Intel
I found the issue.
- Wincent_Altera4 years ago
Glad that you solve the issue, thanks for sharing with me as well
Seen that the problem happens on the refclks settings if follow Error Code 18948
https://www.intel.com/content/www/us/en/support/programmable/articles/000086828.html
With that, I am setting this case to close status at this time.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
I would appreciate taking a moment to fill out the short survey with regards to your experience using Intel Forum.
Wincent_C_Intel
- alexislms4 years ago
Contributor
Before closing the issue, I would like to understand why it doesn't work setting the on-board refclk in SW3.
There is something wrong somewhere, I don't get the Error Code 18948 with the example design since the board is successfully programmed and I can use SignalTap to see the internal signals (cf. the screenshot in the question). However, the board wasn't enumerated.
Is that a hardware issue of the devkit?
No worries, I will remain this case open.
As my understand from your previous reply, you mention that
"the device is enumerated after you set the SW3 as documented, and seen in lscpci. "
As per mention, my understanding is it works as usual already, can I know why suddenly it cannot be enumerate?
Can you clarify more?
Wincent_C_Intel
