Ethernet PHY + MAC debugging
Hu Matthias,
Good day.
I don't have enough information on what type of MAC PHY that you're using. Kindly provide me the details.
Couple things that you can check on auto-negotiation issue
Make sure that both sides of the link are configured the same way.
**If one side of the link is set to auto-negotiation, make sure the other side is also set to auto-negotiation.
**If one side is set to 100/full, make sure the other side is also set to 100/full.
**Failure may happened if one side of the link has been set to 100/full, and the other side has been set to auto-negotiation
This may results in one side being 100/full, and the other side being 100/half.
Auto negotiation must be configure in one PHY mode and one MAC mode
**Auto Negotiation completed but 2 devices run at different speed. It was due to 2 SGMII PCS are configured with Auto Negotiation in MAC mode. In SGMII AN, one PCS must be in MAC mode and the other in PHY mode
Auto Negotiation succeeded with mismatch ability advertised.
**It happened that "SGMII bridge" option was enabled in parameter setting but SGMII ENA bit of IF_MODE register was set to '0'.
**The SGMII mode does not disabled if SGMII bridge is enabled in the parameter setting.
Hence, Auto Negotiation was done in SGMII mode instead of 1000BASE-X mode. dev_ability and partner_ability registers do not take effect in SGMII mode.
