snehal_p
Contributor
3 years agoEthernet GMII to RMII converter ip
Ethernet RMII Interface on the cyclone V board is connected through FPGA IO, to use one of the HPS EMACs we need GMII to RMII converter ip.
Can anyone help with the Ethernet IP to ...
- 3 years ago
Hi snehal_p,
Although the HPS EMAC supports RGMII(dedicated hps part pin), you can try route the EMAC to the FPGA in order to re-use the HPS I/O for other peripherals. When the EMAC is routed into the FPGA it is exposed as a MII/GMII interface. So when the EMAC is routed into FPGA, it support GMII interface.
Zi Ying
ZiYing_Intel
3 years agoHi snehal_p,
Do you still have any question about this case?
Else I would like to have your permission to close the case.
Zi Ying
