snehal_p's avatar
snehal_p
3 years ago
Ethernet GMII to RMII converter ip
Hello, Ethernet RMII Interface on the cyclone V board is connected through FPGA IO, to use one of the HPS EMACs we need GMII to RMII converter ip. Can anyone help with the Ethernet IP to ...
  • ZiYing_Intel's avatar
    3 years ago
    Hi snehal_p,
    Although the HPS EMAC supports RGMII(dedicated hps part pin), you can try route the EMAC to the FPGA in order to re-use the HPS I/O for other peripherals. When the EMAC is routed into the FPGA it is exposed as a MII/GMII interface. So when the EMAC is routed into FPGA, it support GMII interface.
    Zi Ying
