Ethernet GMII to RMII converter ip
- 3 years ago
Hi snehal_p,
Although the HPS EMAC supports RGMII(dedicated hps part pin), you can try route the EMAC to the FPGA in order to re-use the HPS I/O for other peripherals. When the EMAC is routed into the FPGA it is exposed as a MII/GMII interface. So when the EMAC is routed into FPGA, it support GMII interface.
Zi Ying
Hi snehal_p,
Zi Ying
- snehal_p3 years ago
Contributor
Hello Zi Ying,
Thanks for the response.
On cyclone V board we have Ethernet RMII interface through FPGA IO.
As when the EMAC is routed into the FPGA it is exposed as a MII/GMII interface. So when the EMAC is routed into FPGA, it support GMII interface. Can you suggest GMII to RMII converter ip.
snehal_p
