error in ModelSim?
- 1 year ago
Inside the testbench myProject_tb_1.v, make sure the module name also myProject_tb_1.
Sheng
You may re-arrange the sequence of the wire and reg in myProject_tb.v
Sheng
I'm here again with a new problem, sorry.
I wanted to generate several test benches. So, I started again with the wave editor.
- in modelsim deleted wave window
- with text editor modified in wave.do the lines "wave modify ..." for the inputs DI0 ... DI3 to get new input data
- in modelsim loaded the modified wave.do: File / Load / Macro File...
- in modelsim exported the new testbench: File / Export / Waveform... with the new name myProject_tb_1
- closed modelsim
- in Quartus II changed testbench: Assignments / Settings / Simulation / click on Test Benches...
then deleted old test bench "myProject_tb"
added new test bench "myProject_tb_1"
7. started modelsim: Tools / Run Simulation Tool / Gate Level Simulation...
error deleting "msim_transcript": permission denied
8. closed Quartus II and modelsim
9. deleted msim_transcript
10. started Quartus II
11. started modelsim: Tools / Run Simulation Tool / Gate Level Simulation...
# ** Error: (vsim-3170) Could not find 'H:/Arduino/Quartus-Projekte/myProject/simulation/modelsim/gate_work.myProject_tb_1'.
# Error loading design
12. opened myProject_tb_1.v with text editor and saw that it contained only a few lines
13. deleted test bench in Quartus II
14. repeated steps 1 -- 5
15. now myProject_tb_1.v was ok
16. in Quaartus II added test bench myProject_tb_1
17. started modelsim: Tools / Run Simulation Tool / Gate Level Simulation...
same error as in step 11
Is'nt it possible to use several different test benches and if yes how to do it?
