Miles1
3 years agoError during synthesis of MAX 10 FPGA Development Kit sample project 'ddr3x24' in Quartus 20.1.1
I'm using the sample project 'ddr3x24' provided by the MAX 10 FPGA Development Kit. My Quartus version is 20.1.1. However, I'm getting the following error during synthesis. Can you please help me to ...
Miles1
3 years agoI am encountering a different error after updating the IP while using Quartus Prime Lite Edition 21.1.0 .
Error (12006): Node instance "mm_bridge_slv_m0_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_generator_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_checker_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "freq_counter_0_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "timer_0_s1_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "status_mon_0_slv_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mm_bridge_slv_m0_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_generator_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_checker_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "freq_counter_0_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "timer_0_s1_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "status_mon_0_slv_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_003". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_003". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_009" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mm_bridge_slv_m0_limiter" instantiates undefined entity "altera_merlin_traffic_limiter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_generator_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_checker_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "freq_counter_0_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "timer_0_s1_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "status_mon_0_slv_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux_006". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux_006". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo_001" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo_002" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo_003" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_001" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_avalon_st_adapter_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_avalon_st_adapter_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_004" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_005" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_006" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_007" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_008" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "s0" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_s0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "c0" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_c0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_avalon_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_mm_bridge_slv_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_avalon_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_mm_bridge_slv_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_0_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_0_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_0_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "crosser" instantiates undefined entity "altera_avalon_st_handshake_clock_crosser". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "crosser_001" instantiates undefined entity "altera_avalon_st_handshake_clock_crosser". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_read_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_write_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_read_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_write_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_1_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_1_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mm_interconnect_1_router_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux_001" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux_001" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_1_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_0_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "product_info_0_avalon_slave_0_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_0_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "product_info_0_avalon_slave_0_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_2_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_2_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mm_interconnect_2_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_0_master_limiter" instantiates undefined entity "altera_merlin_traffic_limiter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_001" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_001" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_001" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Info (144001): Generated suppressed messages file D:/work/Code/RTL/MAX10/PS2321_EMB/MAX10_DDR3/ddr3x24/output_files/ddr3.map.smsg Error: Quartus Prime Analysis & Synthesis was unsuccessful. 129 errors, 23 warnings Error: Peak virtual memory: 5042 megabytes Error: Processing ended: Wed Apr 12 17:32:14 2023 Error: Elapsed time: 00:00:47 Error: Total CPU time (on all processors): 00:00:50 Error (293001): Quartus Prime Full Compilation was unsuccessful. 131 errors, 23 warnings
Miles1
3 years agoI have resolved the issue by using Quartus Prime Lite 20.1.1 version and updating the IP.
