Miles1
3 years agoError during synthesis of MAX 10 FPGA Development Kit sample project 'ddr3x24' in Quartus 20.1.1
I'm using the sample project 'ddr3x24' provided by the MAX 10 FPGA Development Kit. My Quartus version is 20.1.1. However, I'm getting the following error during synthesis. Can you please help me to ...
AdzimZM_Altera
3 years agoHi,
IP upgrade will update the IP that available in that particular Quartus version.
The newer Quartus version might have some new features added into the IP.
I have tried to replicate the issue at my end but I can successfully run the compilation after upgrading the IPs.
Are you not able to perform IP upgrade?
Adzim
- Miles13 years ago
I am encountering a different error after updating the IP while using Quartus Prime Lite Edition 21.1.0 .
Error (12006): Node instance "mm_bridge_slv_m0_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_generator_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_checker_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "freq_counter_0_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "timer_0_s1_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "status_mon_0_slv_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mm_bridge_slv_m0_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_generator_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_checker_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "freq_counter_0_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "timer_0_s1_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "status_mon_0_slv_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_003". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_003". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_009" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mm_bridge_slv_m0_limiter" instantiates undefined entity "altera_merlin_traffic_limiter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_generator_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "prbs_pattern_checker_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "freq_counter_0_csr_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "timer_0_s1_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "status_mon_0_slv_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_001" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_004" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_005" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_006" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux_006". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_007" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux_006". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_008" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_write_descriptor_slave_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "dispatcher_read_descriptor_slave_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo_001" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo_002" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "async_fifo_003" instantiates undefined entity "altera_avalon_dc_fifo". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_001" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_002" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_avalon_st_adapter_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_003" instantiates undefined entity "q_sys_mSGDMA_0_mm_interconnect_0_avalon_st_adapter_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_004" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_005" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_006" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_007" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_008" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "s0" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_s0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "c0" instantiates undefined entity "q_sys_mem_if_ddr3_emif_0_c0". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_avalon_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_mm_bridge_slv_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_avalon_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_mm_bridge_slv_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_0_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_0_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_0_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_0_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_0_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_0_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "crosser" instantiates undefined entity "altera_avalon_st_handshake_clock_crosser". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "crosser_001" instantiates undefined entity "altera_avalon_st_handshake_clock_crosser". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_read_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_write_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_read_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "msgdma_0_dma_write_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_1_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_1_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mm_interconnect_1_router_002". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_burst_adapter" instantiates undefined entity "altera_merlin_burst_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux_001" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_1_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux_001" instantiates undefined entity "q_sys_mm_interconnect_1_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_rsp_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "mem_if_ddr3_emif_0_avl_cmd_width_adapter" instantiates undefined entity "altera_merlin_width_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_1_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_0_master_translator" instantiates undefined entity "altera_merlin_master_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "product_info_0_avalon_slave_0_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_csr_translator" instantiates undefined entity "altera_merlin_slave_translator". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_0_master_agent" instantiates undefined entity "altera_merlin_master_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "product_info_0_avalon_slave_0_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_driver_msgdma_0_csr_agent" instantiates undefined entity "altera_merlin_slave_agent". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router" instantiates undefined entity "q_sys_mm_interconnect_2_router". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_001" instantiates undefined entity "q_sys_mm_interconnect_2_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "router_002" instantiates undefined entity "q_sys_mm_interconnect_2_router_001". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "master_0_master_limiter" instantiates undefined entity "altera_merlin_traffic_limiter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_demux" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "cmd_mux_001" instantiates undefined entity "q_sys_mm_interconnect_2_cmd_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_demux_001" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_demux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "rsp_mux" instantiates undefined entity "q_sys_mm_interconnect_2_rsp_mux". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Error (12006): Node instance "avalon_st_adapter_001" instantiates undefined entity "q_sys_mm_interconnect_0_avalon_st_adapter". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP. Info (144001): Generated suppressed messages file D:/work/Code/RTL/MAX10/PS2321_EMB/MAX10_DDR3/ddr3x24/output_files/ddr3.map.smsg Error: Quartus Prime Analysis & Synthesis was unsuccessful. 129 errors, 23 warnings Error: Peak virtual memory: 5042 megabytes Error: Processing ended: Wed Apr 12 17:32:14 2023 Error: Elapsed time: 00:00:47 Error: Total CPU time (on all processors): 00:00:50 Error (293001): Quartus Prime Full Compilation was unsuccessful. 131 errors, 23 warnings- Miles13 years ago
I have resolved the issue by using Quartus Prime Lite 20.1.1 version and updating the IP.
- Miles13 years ago
By the way, is this IP free of charge?
DDR3 SDRAM Controller with UniPHY Intel FPGA IP
Name
altera_mem_if_ddr3_emif
Version
20.1
Author
Altera Corporation
Description
