app_engineer
4 years agoError (18948): Error message received from device: Bitstream error. (Subcode 0x0001, Info 0x00000003
While trying to program the board: 1) USB-BlasterII [1-2.3] C32250DD 1SG280HH1(.|S3|AS|BK)/.. I am getting an error in quartus programmer: Error (18950): Device has stopped receiving conf...
Ash_R_Altera
4 years agoHi,
Can you please check the following article, if any of the conditions are applicable to you?
https://www.intel.com/content/www/us/en/support/programmable/articles/000086828.html
- app_engineer4 years ago
The resolution says that one of the IPs installed doesn't have the correct clock configuration.I checked my design and the only IP that I witnessed was added is the SDM_IO for VID operation.
Upon opening the PIN planner it seems that the SDM bank has ZERO assignable Pins as shown below:
Can you provide more details as to how to add the clock configuration for this IP.
