EP4CE55F23I7N
Why does Kr origin have secondary coating? Is it a matter of workmanship?
But the X-ray showed that the acetone cover was opened and passed
Can you explain it for us?
EP4CE55F23I7N Sample 1 Lot:S112MK80 Date:2113 COO:TW
EP4CE55F23I7N Sample 2 Lot:S002AF25 Date:2001 COO:KR
EP4CE6F17C8N Sample 3 Lot:S042AK5F Date:2043 COO:KR
Lot:S115AF10 Date:2113 COO:KR
- AqidAyman_Altera
May I know what did you mean by Kr origin have secondary coating?
Aqid Ayman
- Lida8
The red arrow, you can compare the plastic body of KR origin and TW origin
- AqidAyman_Altera
I will check with the internal team which responsible for the packaging issue. Will back to you soon as I got the answer.
Aqid
- AqidAyman_Altera
Apologies to inform you that the lot number you provided for Sample 2 and Sample 3 are invalid lot number as per check by internal team.
I afraid I could not provide further support because on this. You may need to check first with the distributor where you purchased the part. I hope you understand.
