EMIF HPS errors after upgrading to Quartus 25.3
- 11 months ago
Can you check in the design for pin placement of the user reference clock? Is it placed in Bank 3A?
Can you check for the pin swizzling parameter in the EMIF HPS IP?
Adzim
Adzim
- pmarques11 months ago
Hello AdzimZM_Altera,
Thanks for the pointers, it was indeed the pin swizzling and other parameters hidden inside the "Dive into Packaged Subsystem" of the EMIF HPS IP.
Initially after I upgraded the EMIF HPS IP, it appeared without any interfaces:
So I deleted the component and instantiated a new one but apparently caused all the hidden parameters to be reset. I was assuming these hidden parameters would be automatically set since Quartus knows I'm using a devkit.
