TobiasS98
3 years agoE-Tile not working with custom pattern ?
I am currently trying to implement an E-Tile into my design. I used a tcl script and the system console to make a test with PRBS31 and the setup. Using PRBS31 with Serial Loop as well as with m...
Kshitij_Intel
3 years agoHi,
It's good to hear you are getting zero BER now.
Just wanted to check for the user defined pattern are you following the steps mentioned in the below link.
Also, please check the transmit adaption order select which determines the how 64 bits sent to 32-bit transceiver channel.
https://www.intel.com/content/www/us/en/docs/programmable/683723/current/pma.html
Hope this will resolve your issue.
Thank you
Kshitij Goel
