E-Tile not working with custom pattern ?
Can you please check are you configuring the 0x84 = 3b'111 for the user pattern.
Please refer to the link below for more information.
https://www.intel.com/content/www/us/en/docs/programmable/683723/current/prbs-usage-model.html
Thank you
Kshitij Goel
It did set those bits. I am also now able to get a zero bit error. Though If I capture the data via the PMA register they do not fit my pattern at all. How exactly is this data captured ?
- TobiasS983 years ago
I have added the result of my signal analyzer. The received data do to equal the one I send. I already checked the TX signal with an oscilloscope. I also took an eye diagram. Both looked fine. The connection is etablished as described in the guide and rx and tx both signal ready and rx_lockedtodata is also true.
Using the internal PRBS31 I got 0 bit error. So the signal quality should be good enough.
