DPX4 and DPx8 PHY
I am trying to build a PHY for DisplayPort 5.4GHz design we have. I am trying to set Dp-PHY with 4-lanes and 8-lanes, I encountered couple of issues during the process:
- first how can I configure PHY from the IP catalog? I don't see that the dp protocol is in the PHY selection, while using direct PHY configuration.
- If I select the DisplayPort IP (PHY+Bitec decoder), I see that it only supports DP 4lanes. Can I configure the DP PHY to be 8 lanes?
I will appreciate your help on this subject.
Elad Rotem
- HelenMa
Hi Elad,
No, your understanding is wrong.
1. Currently Agilex7 F-tile transceiver IP can't be modified for DP application, it's only available for DP 4lanes. Please do not develop your DPx8 prject using Agilex7.
2. Arria10/Stratix10 transceiver IP can be modified in the transceiver IP GUI. So you can develop your DPx8 project using Arria10/Stratix10.
3. Arria10/Stratix10 transceiver is different from Agilex7. You can't integrate it into Agilex7 design.Best Regards,
Helen- Elad0708
Hi Helen,
Thank you for your support.
Elad Rotem
- WZ2
Hi there,
I wanted to check if you have any further questions or concerns. If not, I will go ahead and mark this issue as resolved.
Additionally, we would greatly appreciate it if you could take a moment to fill out our survey. Your feedback is valuable to us and helps us improve our support quality.
Thank you for your time and cooperation.
WZ
