DPX4 and DPx8 PHY
Hi Elad,
Please instance the DisplayPort Intel FPGA IP directly. You can generate the DisplayPort Example design after the IP generation. The Transceiver Native PHY Intel FPGA IP is included.
The DisplayPort Intel FPGA IP can be set to 1,2,4 lane per the DisplayPort protocol. If the design needs 8 lanes please instance the DisplayPort Intel FPGA IP twice.
Aaron
Appreciate your help on this!
So, I follow your instructions and the project finish synthesis. Two question I have:
1. Since I want to create 8-lanes and not two channels of DisplayPort, I created two instances of PHY. Both PHY's drive 'gxb_tx_clkout' so which one I should use? The DisplayPort controller should work only with one recovered clock.
2. Also, the analog parameters (vod & emp) disturbed me, since DisplayPort controller will need to check this two PHYs separately.
Can't I configure this one instance of PHY ('tx_phy_top' in the example design) to work with 8 lanes?
Elad Rotem
- zhenruan2 years ago
Hi Elad,
You can't instance one 8-channel Transceiver Native PHY to work with 2 HDMI interface (HDMI source/HDMI sink). The HDMI source/sink doesn't support the lane number exceeding 4.
As the design needs 8 lanes DisplayPort, you can divide it into two groups. Each group works separately.
One 4-lane DP sink IP needs one 4-channel Transceiver Native PHY RX IP.
One 4-lane DP source IP needs one 4-channel Transceiver Native PHY TX IP.
Aaron
