Documentation Max 10 Nios Simple Socket
I'm trying to access the documentation for the Max 10 Development Kit Simple Socket tutorial. (Located here: https://www.intel.com/content/www/us/en/design-example/714915/max-10-nios-ii-simple-socket-server-ethernet-example.html?wapkw=Simple%20Socket%20Server%20Max%2010)
The link to this PDF is broken:
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/e/e5/Simple_Socket_Ethernet.pdf
Can you guys fix your own links? This is frustrating. If not, can someone send me this PDF?
Hi ANA ESCALERA
you can find out the documentation for the Max 10 Development Kit Simple Socket tutorial in bellow given link. please go through it.
- hareesh
Hi ANA ESCALERA
I saw your issue. We tried to get those documents, but some of the content may be missing due to an upgrade to the web portal a few months back. I requested page owners from my side. Maybe it will take 2 to 3 days to solve the problem.
- hareesh
Hi ANA ESCALERA
- hareesh
Hi ANA ESCALERA,
Since I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
I shall set this case to close pending,
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Hareesh B.
