13 years agodevkit startix5 pcie-demo issue
Hi all,
i tried to run demo pcie example that shipped with kit but it stall at ltssm: detect.Active !! , i know that was issue at ACDS less than 12 , but i'm using 13 the example provided use hard IP pcie with X8 and gen2 , Avalon_st as application and print out link state and on board LED . have anyone face such issue ? thanks, Amr4 Replies
do you re-generate pcie-core?
--- Quote Start --- Hi all, i tried to run demo pcie example that shipped with kit but it stall at ltssm: detect.Active !! , i know that was issue at ACDS less than 12 , but i'm using 13 the example provided use hard IP pcie with X8 and gen2 , Avalon_st as application and print out link state and on board LED . have anyone face such issue ? thanks, Amr --- Quote End --- - Altera_Forum
yes i generated another one with same connection of example ,but i've figure out problem cause :
we must set test_in[5] = 0; to allow pcie enter compliance mode the another issue now that Ltssm stall at Polling.Compliance(3) state !! i doubt that the cause of this problem from either "reconfig_xcvr_clk" as it set to 125MHz and have timeQuest -ve slack or "I\O pin standard" as it silghtly different from rerferance manul of kit thanks, - Altera_Forum
I am having a similar issue with the Cyclone IV devkit. I have set test_in to be 40'h88, and on certain ports of my Dell computer the board stalls on the LTSSM state "Polling.Compliance".
Any help would be appreciated. - Altera_Forum
this values of test_in that make my dev kit run successful training:
test_in[4:0] = 5'b01000; test_in[5] = 0; test_in[31:6] = 26'h2; and please make sure of pcie lane switch of your kit . it should match your design's lanes. thanks, Amr
