DGaik
7 years agoDear, On the KIT MAX R 10 10M08 Eval Kit Board is it possible change the voltage of the regulator EP5388QI from 3.3V to 2.5V? The VCC_CORE can be 2.5V for the proper operation? I not using the Arduino or Opamps circuits from this board.
DGaik
7 years agoDear, Just to check , the idea is remove the R4 and connect an external board regulator on the J2.
Its possible? The FPGA partnumber used on this board said that this is a Single Supply and can work with 3.3V on core and 2.5V on VCCIOs.
Daniel.
- AnandRaj_S_Intel7 years ago
Hi Daniel,
Yes, We can remove the R4 and use J2.2 for external supply.
VCCIO is not monitored by POR so we can supply it any time we required. example : We can also power up VCCIO for IO banks individually after configuration based on our design requirements.
So, I am not seeing any problem, But however Intel will not be liable for any damage that you may occur as a result of modification, either with or without your knowledge.
Anand
