DGaik
7 years agoDear, On the KIT MAX R 10 10M08 Eval Kit Board is it possible change the voltage of the regulator EP5388QI from 3.3V to 2.5V? The VCC_CORE can be 2.5V for the proper operation? I not using the Arduino or Opamps circuits from this board.
DGaik
7 years agoDear, The Idea is disconnect R4 and on TP5 side is connect the output from one external regulator with 2.5V, the bad side is to connect an external board with a regulator.
Dan
