DGaik
7 years agoDear, On the KIT MAX R 10 10M08 Eval Kit Board is it possible change the voltage of the regulator EP5388QI from 3.3V to 2.5V? The VCC_CORE can be 2.5V for the proper operation? I not using the Arduino or Opamps circuits from this board.
DGaik
7 years agoDear,
I think the best way is disconnect the R4 Shunt resistor and supply the 2.5V using an external regulator connected in a J2 connector.
At least there are a possibility to use a external board. Thank you , if You have better suggestion , please, share.
Dan
- AnandRaj_S_Intel7 years ago
Hi Dan,
If we remove the R4 still, we will get 3.3V only.
Layout is designed like that. We don't have any via at R4.
Anand
