14 years agoDE2-115 Ethernet throughput
I'm trying to send a video flow from my DE2-115 to a PC. To send 320*240 images with 16bit pixels with 25fps, I need a throughput of 320*240*16*25 = 30,720,000bit/s (below the 100Mbit/s offered by th...
14 years agoThank you for your answers.
I increased the instruction and the data caches to the max and gained some fps. I think the bottleneck is the AVALON bus. Before writing my own transport protocol, I want to try to separate the data and the instruction busses to reduce this bottleneck. I didn't find any documentation on google for that, and when I try with a simple example (a NIOS, a jtag_uart, and two on_chip memories, with a hello_world_small template) it doesn't work. Did I miss some documentation ? Do I have to change something in the configuration of the nios compiler ?
