Marco_Go
3 years agoDE10LITE SDRAM Example code
Dear Sirs,
I did several tests using the de10-lite including using the files that come with the board. As I have no experience, I could not find out if the card is having problems or if I really ...
- 3 years ago
Hello Marco,
You need to check that your RTL code is correct before you solve the timing violation.
Any changes made to the RTL code could definitely affect the timing performance due to different routing.
Also, if you require help on timing, please post a new thread as this thread has a different root cause & solution.
Thank you,
Nurina
Nurina
3 years agoHello Marco,
Thank you,
Nurina
Marco_Go
3 years agoHi Nurina,
regards,
Marco
