DE10LITE SDRAM Example code
- 3 years ago
Hello Marco,
You need to check that your RTL code is correct before you solve the timing violation.
Any changes made to the RTL code could definitely affect the timing performance due to different routing.
Also, if you require help on timing, please post a new thread as this thread has a different root cause & solution.
Thank you,
Nurina
Hello Marco,
I'm glad to hear that your design is working.
If you are a beginner at RTL simulation, you may find this document useful: https://www.intel.com/content/www/us/en/docs/programmable/683248/18-0/simulation-quick-start.html
With that, I now transition this thread to community support. If you have a new question, please login to https://supporttickets.intel.com , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 4/5 survey
Nurina
- Marco_Go3 years ago
Hi Nurina,
I would like you to help me solve the timing problems as well so I would have the project completely without any errors. I don't know how to do that or get it right in Quartus.
regards,
Marco
