DE10LITE SDRAM Example code
- 3 years ago
Hello Marco,
You need to check that your RTL code is correct before you solve the timing violation.
Any changes made to the RTL code could definitely affect the timing performance due to different routing.
Also, if you require help on timing, please post a new thread as this thread has a different root cause & solution.
Thank you,
Nurina
Hello Marco,
How about this design example? https://www.intel.com/content/www/us/en/design-example/715013/max-10-sdram-rtl-test-max10-de10-lite.html?wapkw=de10%20lite%20sdram
It should work on Quartus Lite as well. Please let me know if you have any problems.
Nurina
Hi Nurina,
As I informed you earlier, this project that you sent me is the same one that is on the CD that comes with the board and I couldn't write the data and read the data. I made some changes and it doesn't work as I informed you earlier.
For example, I would like to record 5 data in 5 different positions in memory and then read this data. I tried to test with this code example and it didn't work, I tried with other codes and it didn't work either. The code I'm testing now, I record a value and when I read it I get another one. If you want I can upload the code for you to check there in DE10.
Marco
