CAlex
Contributor
3 years agoDe10 standard Clock and speed issue
I'm a little confused on the clock issues, I'm working on Liunx based system with the debug mode.
I created a flag signal that it will flip in 50us.
I posted the signal from the FPGA to the...
EBERLAZARE_I_Intel
3 years agoHi,
From my understanding, the settings are carried over by the handoff folder from Quartus when you build the U-boot, which is why the U-boot need to be regenerated when changing the HPS IP's settings.
Maybe you could use the default image from Terasic and see if using the default differs or seeing the same issue using the default clock settings?
- CAlex3 years ago
Contributor
Good idea, I will have a try.
