DE10-nano fails to boot with OpenCL linux image
I am trying to boot my DE10-nano with "de10_nano_opencl_18.1.img" from here , but boot is interrupted and stuck as below. The board was working fine with the default image that was initially loaded to the SDcard.
U-Boot 2013.01.01 (Nov 26 2018 - 18:51:04)
CPU : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
reading u-boot.scr
170 bytes read in 7 ms (23.4 KiB/s)
## Executing script at 02000000
reading opencl.rbf
3053100 bytes read in 176 ms (16.5 MiB/s)
## Starting application at 0x3FF79598 ...
## Application terminated, rc = 0x0
reading zImage
3616336 bytes read in 223 ms (15.5 MiB/s)
reading socfpga.dtb
18671 bytes read in 12 ms (1.5 MiB/s)
## Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x00000100
Loading Device Tree to 03ff8000, end 03fff8ee ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Linux version 3.13.0-00299-ga2e769f ([email protected]) (gcc version 4.8.3 20140401 (prerelease) (crosstool-NG linaro-1.8
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Altera SOCFPGA Cyclone V SoC Development Kit
cma: CMA: reserved 512 MiB at 20000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @80fb7000 s11264 r8192 d13312 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 rw rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 506276K/1048576K available (5444K kernel code, 259K rwdata, 1468K rodata, 367K init, 260K bss, 542300K reserved)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xc0800000 - 0xff000000 (1000 MB)
lowmem : 0x80000000 - 0xc0000000 (1024 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x806c846c (6914 kB)
.init : 0x806c9000 - 0x80724c00 ( 367 kB)
.data : 0x80726000 - 0x80766fb8 ( 260 kB)
.bss : 0x80766fb8 - 0x807a8224 ( 261 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:16 nr_irqs:16 16
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949672950ns
Console: colour dummy device 80x30
Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
ftrace: allocating 18159 entries in 54 pages
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x4ec648 - 0x4ec6a0
CPU1: failed to come online
Brought up 1 CPUs
SMP: Total of 1 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
NET: Registered protocol family 16
fpga bridge driver
DMA: preallocated 256 KiB pool for atomic coherent allocations
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410030c9, AUX_CTRL 0x32460000, Cache size: 512 kB
syscon fffef000.l2-cache: regmap [mem 0xfffef000-0xfffeffff] registered
syscon ffd05000.rstmgr: regmap [mem 0xffd05000-0xffd05fff] registered
syscon ffc25000.sdrctl: regmap [mem 0xffc25000-0xffc25fff] registered
syscon ff800000.l3regs: regmap [mem 0xff800000-0xff800fff] registered
syscon ffd08000.sysmgr: regmap [mem 0xffd08000-0xffd0bfff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
altera_hps2fpga_bridge fpgabridge.2: fpga bridge [hps2fpga] registered as device hps2fpga
altera_hps2fpga_bridge fpgabridge.2: init-val not specified
altera_hps2fpga_bridge fpgabridge.3: fpga bridge [lshps2fpga] registered as device lwhps2fpga
altera_hps2fpga_bridge fpgabridge.3: init-val not specified
altera_hps2fpga_bridge fpgabridge.4: fpga bridge [fpga2hps] registered as device fpga2hps
altera_hps2fpga_bridge fpgabridge.4: init-val not specified
bio: create slab <bio-0> at 0
FPGA Mangager framework driver
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
lcd_load_custom_fonts: i2c_master_send returns -121
lcd_cmd_no_params: i2c_master_send returns -121
lcd_cmd_one_param: i2c_master_send returns -121
lcd-comm 0-0028: LCD driver initialized
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
PTP clock support registered
Switched to clocksource timer1
NET: Registered protocol family 2
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
arm-pmu arm-pmu: PMU:CTI successfully enabled for 1 cores
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
NTFS driver 2.1.30 [Flags: R/W].
jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 2012
io scheduler noop registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
ffc02000.serial0: ttyS0 at MMIO 0xffc02000 (irq = 194, base_baud = 6250000) is a 16550A
console [ttyS0] enabled
altera_fpga_manager ff706000.fpgamgr: fpga manager [Altera FPGA Manager] registered as minor 0
brd: module loaded
at24 0-0051: 4096 byte 24c32 EEPROM, writable, 32 bytes/write
cadence-qspi ff705000.spi: cannot get qspi clk
cadence-qspi: probe of ff705000.spi failed with error -2
dw_spi_mmio fff00000.spi: master is unqueued, this is deprecated
CAN device driver interface
c_can_platform ffc00000.d_can: invalid resource
c_can_platform ffc00000.d_can: control memory is not used for raminit
c_can_platform ffc00000.d_can: c_can_platform device registered (regs=c089e000, irq=163)
stmmac - user ID: 0x10, Synopsys ID: 0x37
Ring mode enabled
DMA HW capability register supported
Enhanced/Alternate descriptors
Enabled extended descriptors
RX Checksum Offload Engine supported (type 2)
TX Checksum insertion supported
Enable RX Mitigation via HW Watchdog Timer
libphy: stmmac: probed
eth0: PHY ID 00221622 at 1 IRQ 0 (stmmac-0:01) active
dwc2 ffb40000.usb: unable to find phy
dwc2 ffb40000.usb: EPs:15
dwc2 ffb40000.usb: dedicated fifos
dwc2 ffb40000.usb: 2560 invalid for host_rx_fifo_size. Check HW configuration.
dwc2 ffb40000.usb: 2560 invalid for host_nperio_tx_fifo_size. Check HW configuration.
dwc2 ffb40000.usb: DWC OTG Controller
dwc2 ffb40000.usb: new USB bus registered, assigned bus number 1
dwc2 ffb40000.usb: irq 160, io mem 0x00000000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: DWC OTG Controller
usb usb1: Manufacturer: Linux 3.13.0-00299-ga2e769f dwc2_hsotg
usb usb1: SerialNumber: ffb40000.usb
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usbcore: registered new interface driver usb-storage
mousedev: PS/2 mouse device common for all mice
rtc-ds1307: probe of 0-0068 failed with error -5
i2c /dev entries driver
Synopsys Designware Multimedia Card Interface Driver
dwmmc_socfpga ff704000.dwmmc0: Using internal DMA controller.
dwmmc_socfpga ff704000.dwmmc0: Version ID is 240a
dwmmc_socfpga ff704000.dwmmc0: DW MMC controller at irq 171, 32 bit host data width, 1024 deep fifo
dwmmc_socfpga ff704000.dwmmc0: 1 slots initialized
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
oprofile: using arm/armv7-ca9
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
ThumbEE CPU extension supported.
Registering SWP/SWPB emulation handler
Waiting for root device /dev/mmcblk0p2...
mmc0: Problem switching card into high-speed mode!
mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 25000000Hz, actual 25000000HZ div = 1)
mmc0: new SDHC card at address 0001
mmcblk0: mmc0:0001 SD16G 7.44 GiB
mmcblk0: p1 p2 p3
EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 364K (806c9000 - 80724000)
Thank you
Georgios Flamis, Ph.D. student, Member of Electronic Circuits,Systems and Applications (ECSA) Lab, Electrical & Computer Engineering Department, University of the Peloponnese, Megalou Alexandrou 1 str., (Building K', 1st Floor), Koukouli, Patras, GR-26334, Greece Skype: gflamis Email:[email protected] Webpage:https://sites.google.com/view/ecsalab/
