DE10-Nano device tree (dts) in kernel sources
- 3 years ago
Hi davidyu1,
Sorry for late reply.
For your reference, Below is the example for DE0_nano board FPGA LED enablement.
Try to refer this link on how to enable the FPGA LEDs:
Check step 2: Hardware Design Overview
You will need to have the LED component placed inside your Qsys project. The LED pin assignment (can check with pin planner) is pointing to the dedicated FPGA pins of the board mentioned in the board user guide.
Check step 6: Generating and Compiling the Device Device Tree
You can see how the device tree look like for LED enablement of the project.
When your system boot up to U-boot, you can access the address which bridge the HPS->FGPA, referring to the address of the Qsys connections of the project.
Make sure bridge is enabled in U-boot with bridge enable cmd.
Make sure you already flashed in the FPGA design in the FPGA fabric.
Then in U-boot, you can use md cmd to set the address of the LED bits to on/off
After system boot into linux kernel, you can use devmem cmd to set the address of the LED bits to on/off.
Observe the LEDs lights on the board.
Aik Eu
In additon,
When I tried to upgrade kernel version with de0 device tree, I can not find the "gpio-leds" of fpga-region in the device tree.
