15 years agoDE0 Nios II EPCS boot
I am having problems using the flash programmer to load my .sof and .elf files onto the EPCS4 chip of my Terasic DE0 dev board (Cyclone III). My SOPC has an EPCS controller and the reset address of t...
14 years agoto those who got the same problem , to let you know i found the solution at least for my case ;-) here is how :
- note i was not running it not on a DE0 devp kit , but on a smaller custom devp board CycloneII - running NiosII flash prog in debug mode from command line & adding the --debug option , i found the problem was linked to the data contents read from the EPCS chip registers - from this error i found some tips in Altera Knowledge Base , saying it can be linked to the EPCS controller not being in the proper RESET state when trying to be accessed by the JTAG module inside the NiosII cpu - so back into back into my QSys design i realized that the EPCS flash controller had its RESET connected to the main Clk_Reset , but not to the JTAG_Reset : so i rebuilt in QSys after having connected the EPCS controller to the JTAG_Reset of NiosII - then i recompiled in Quartus , then on to NiosII SBT : then into Flash Programmer i selected to flash into the EPCS : 1st area the converted-SOF of the design , followed by 2nd area the converted-ELF which should include the "--after ..." option : this is VERY important to make sure you flash your NiosII-software-ELF part !AFTER! the "SOF" general fpga configuration part (produced from QuartusII) : in my case i wanted both fpga-configuration + nios2-software to be inside the EPCS flash chip , so this option was needed (read the NiosII Flash Programmer pdf guide for more details , some are really important depending on your custom board's config) - after that all was ok :-)
