14 years agoDDR LVDS over HSMC on Stratix IV GX Development Kit
Can the HSMC interfaces on the Stratix IV GX development board support 500 MHz (1000 GBPS) DDR LVDS?
--- Quote Start --- Can the HSMC interfaces on the Stratix IV GX development board support 500 MHz (1000 GBPS) DDR LVDS? --- Quote End --- I don't see why not. I have been using the transceivers at 5Gbps and higher. Assuming the LVDS layout is good, you should be fine. I've tested the Stratix II LVDS at 1Gbps. I would expect the Stratix IV to work fine. What are you interfacing to? Cheers, Dave - Altera_Forum
Dave,
Thanks for your reply. Yes, it's the LVDS routing of the Stratix IV GX development board that I'm concerned with. I would like to know if it is good enough for 1 Gbps. I'm interfacing to an Analog Devices AD9434 12-bit 500 MSPS ADC. It supports both SDR and DDR transmission. I'll use the SDR mode at first but would like to try the DDR mode, as well. http://www.analog.com/en/analog-to-digital-converters/ad-converters/ad9434/products/product.html Andy - Altera_Forum
Hi Andy,
--- Quote Start --- Yes, it's the LVDS routing of the Stratix IV GX development board that I'm concerned with. I would like to know if it is good enough for 1 Gbps. --- Quote End --- It should be. Do you have the board? If you don't, I could probably test the boards I have. But I wouldn't get a chance to until next week sometime. Unless of course you have a test design, that has a nice testbench, so that I can see the design, then I'll download it :) --- Quote Start --- I'm interfacing to an Analog Devices AD9434 12-bit 500 MSPS ADC. It supports both SDR and DDR transmission. I'll use the SDR mode at first but would like to try the DDR mode, as well. http://www.analog.com/en/analog-to-digital-converters/ad-converters/ad9434/products/product.html Andy --- Quote End --- Does your design provide a frame clock for the LVDS demux logic? Read these if you don't know what I'm talking about: http://www.ovro.caltech.edu/~dwh/carma_board/at84ad001b_tests.pdf http://www.ovro.caltech.edu/~dwh/carma_board/digitizer_tests.pdf Cheers, Dave
