Daughter cards for DK-SI-AGI027FB
I am looking to build an emulation platform using DK-SI-AGI027FB to interface to PCIe switches with SFF-8644 interface.
My requirement is
-on chip processor
-preferably four Gen3x8 PCIe ports (alternately four Gen3x4 ports) connected via SFF-8644
I am thinking of having a daughter card that would have four SFF-8644 connectors (two for each PCIe port if using x8 and one for each PCIe port if using x4). The cards has two FMC+ connectors, so I can get four ports on there.
1. Is there a different/better solution
2. Are there FMC daughter cards with SFF-8644? I can not find any
Thank you
If you are trying to build PCIe Switch using Agilex device
Initially you can refer to our switch IP on- https://www.intel.com/content/www/us/en/products/details/fpga/intellectual-property/interface-protocols/pcie-scalable-switch.html?wapkw=pcie%20switch
- https://www.intel.com/content/www/us/en/docs/programmable/683515/20-4-1-0-0/introduction.html
For the daughter card that would have four SFF-8644 connectors, I wish to help on it, but my answer might not be so accurate.
Perhaps you can check with the distributor if they have that product or not.
Regards,Wincent_Intel
- Wincent_Altera
Thank you for reaching out.
Just to let you know that Intel has received your support request and I am assigned to work on it.
Allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Wincent_Intel
- Wincent_Altera
- Ben14
Thank you
- Wincent_Altera
Hi
Thanks for confirming the answer
This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
- Wincent_Altera
Thanks for confirming the answer. With that said, I am closing this from my sides.
Wincent_Intel
