11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- Could you explain what I would need to do in both cases? --- Quote End --- First you need to clearly define what it is you are trying to do. From that we can understand the data rate you need between the FPGA and your PC. That will determine which option is suitable for your application. Cheers, Dave
