11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- ... you might get to your end goal faster (cheaper) by using something like FTDI UM232H module if your DE0-nano header pins aren't already used up. --- Quote End --- Here are performance measurements ... https://www.ovro.caltech.edu/~dwh/correlator/pdf/ftdi.pdf Cheers, Dave
