11 years agoData from FPGA to host
Hi, I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read th...
11 years ago --- Quote Start --- I have a DE0-nano board and I compute data (only 4 bits generated at about 10MHz) and I'd like to communicate it to the host cpu through the USB-blaster so programs could read it. I've read this and there's instructive information but it's a bit old and maybe there exist other ways. --- Quote End --- In addition to the JTAG UART, those are still the only ways you can transfer data :) http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial I haven't used the JTAG UART, but I think it suffers from the same problem the other interfaces do; no easy way to access the UART from user-provided software, eg., the JTAG UART does not show up as a COM port. --- Quote Start --- I thought about a FIFO that would be written by the FPGA then read by the host through the USB link. Is it possible? Have I to use a virtual JTAG component? --- Quote End --- The problem is, that the USB interface is not a general purpose USB interface. Its a USB-Blaster and it is "owned" by Quartus and jtagd. You can access it using FTDI's D2XX DLLs directly, but I'm not sure whether that "plays nicely" if you also happen to be using Altera's tools at the same time. The Wiki tutorial contains code for accessing the JTAG-to-Avalon-MM bridge via Altera's tools, and that is pretty much the only safe way to access the board via JTAG. It would be nice if Altera would publish their jtagd protocol, as then you'd be able to write sockets code to interact with jtagd, which would in turn interact with the JTAG interface on the FPGA (in a multi-process safe manner, since all communications is via jtagd). You could just buy an FTDI C232H cable and communicate with the board via that method. Cheers, Dave
