16 years agoCycloneIII FPGA Starter kit DDR clock pins and main oscillator voltage
Hi, I am designing a board with a CycloneIII device and some DDR memory. Having a look to the Cyclone III FPGA starter kit board, I can not quite understand a couple of points: - The m...
16 years agoHello,
just an update to all of you reading my post. Today I received my board and I am quite relieved as it seems working fine. So, summarizing my results: - Using the 2.5V oscillator clocks fine the FPGA device (not really surprisingly as the bank is supplied with 2.5V); I am still wondering why Terasic is using a 3.3V oscillator on their Cyclone III FPGA Starter kit. - Like Terasic, I connected the mem_clk pins for the DDR memory to the output pins of the PLLs; - Modifying the mode of the PLL of the "slave" DDR controller to no-compensated removes the critical warning and saves functionality of the system. I can run my DDR memory test program (I write the whole DDR memory chips with a pattern and read it back for verification). I hope the above is useful. If anybody has different results, please, let me know. Michele
