16 years agoCycloneIII FPGA Starter kit DDR clock pins and main oscillator voltage
Hi, I am designing a board with a CycloneIII device and some DDR memory. Having a look to the Cyclone III FPGA starter kit board, I can not quite understand a couple of points: - The m...
16 years agoI decided to have CK/CKn of the DDR directly connected to the PLL output pins in my board, just like the Cyclone III FPGA starter kit board. I still have doubts but, at the end of the day, the Terasic board works fine so, at the moment, this is the safest option.
On the other side, I will use a 2.5V output oscillator at the beginning as it could be easily replaced without any pain. In the meantime, I had the need to add another DDR chip in the design and another problem has arisen: I tried to compile a design with 2 DDR controllers and, basically, I did something very very similar to what I found at page 17 of "an 462: implementing multiple memory interfacing using the altmemphy megafunction": there is one clock source feeding both refclk inputs of the DDR controllers (this is a SOPC builder request), one of them is a kind of slave, has the "uses clocks from another controller" option ticked so it receives the sysclk (from the other DDR controller) on its shared_sys_clk input. The sysclk is the clock for the rest of the system as well. The SOPC builder is happy with this configuration and completes the generation process successfully. When I launch the compilation process, from QuartusII I get the following : "critical warning: pll ddr1:the_ddr1|ddr1_controller_phy:ddr1_controller_phy_inst|ddr1_phy:ddr1_phy_inst|ddr1_phy_alt_mem_phy:ddr1_phy_alt_mem_phy_inst|ddr1_phy_alt_mem_phy_clk_reset:clk|ddr1_phy_alt_mem_phy_pll:pll|altpll:altpll_component|altpll_gqg3:auto_generated|pll1" input clock inclk[0] is not fully compensated because it is fed by a remote clock pin "pin_ab12" I understand this happens because, I am not feeding the "slave" DDR controller PLL (the refclk input) with the input pin it is meant to be fully compensated but I am doing it internally from the clock pin related to the other DDR controller. Am I right? - Should I connect my external oscillator to both the FPGA pins related to the PLLs I am using and instruct QuartusII in this sense? - Is it safe to modify the mode of the PLL of the "slave" controller to no-compensated ? (QuartusII compiles with no critical warnings in this case) Any help is very well wellcomed. Michele
