Ranjithkumar828
3 years agoCyclone V SoC Ethernet speed issue bare metal driver
We have developed an ethernet driver for Cyclone V SoC in bare-metal programming. When we are transmitting more than 80 bytes per packet in our customized board it is getting failed. But the ...
- 3 years ago
Hi Aik Eu,
The above issue is soved. Some macros related to dma configuration are commanded in code. After removing the command it is solved.
Ranjithkumar828
3 years agoHi Aik Eu,
GOMEZ_IT
2 years agoHi Ranjithkumar828..
Could you share the driver you created to send/receive UDP packets from the ethernet port?
I'm trying to do the same thing you did but with a DE10 nano board, for now without success, because I can't find a baremetal driver on the internet that allows me to use the ethernet port to send simple raw packets.
Would you be willing to give me some help?
Thank you,
Luca.
