Cyclone V SOC development kit boot up error with factory default settings
- 5 years ago
I solved the problem. There was something wrong with the SD Card image. I tried the factory recovery image & the image from rocketboards.org. They both did not work. We bought 2 boards at the same time and the second one booted up fine. I cloned the image and it worked on the first board. It's unfortunate that you don't a repository of the correct images.
I am going through purgatory trying to get my brand new Cyclone V SOC Dev git to boot the Pre compiled Linux image.
Any help is much appreciated.
Do you still have a copy of the image that worked for you?
Would you have at least an image of the board as configured and working?
Including jumpers, DIPS and lights.
I only have one board but have been around the loop numerous times with no progress
Thanks Martin
