Cyclone V SOC development kit boot up error with factory default settings
- 5 years ago
I solved the problem. There was something wrong with the SD Card image. I tried the factory recovery image & the image from rocketboards.org. They both did not work. We bought 2 boards at the same time and the second one booted up fine. I cloned the image and it worked on the first board. It's unfortunate that you don't a repository of the correct images.
Yes, this is a brand new board. I used the SD image that is on the flash card placed on the board.
When I tried to program the FPGA (factory default - system_max_RevE1.pof) it said "failed". I can see the components in JTAG chain. Do I need to set the SEL CON (three LEDS right next to CPU Rest) in mode 1? The board powers up with LED at 0 lighting up.
Thank you for your help.
We regret that you faced such issue, typically you can already boot the Cyclone V SoC Dev Kit board without any changes with the SD Card image or download prebuilt images from the rocketboards:
https://releases.rocketboards.org/release/2019.10/gsrd/cv_gsrd/
Alternatively you can build your own:
https://rocketboards.org/foswiki/Documentation/BuildingBootloader#Cyclone_V_SoC_and_Arria_V_SoC
