MohanY
5 years agoCyclone V SOC development kit boot up error with factory default settings
I am getting the following error with the Cyclone V SOC development kit on powering up. I made sure all the jumpers are set according to the user guide. This is what I am seeing on UART (Ter...
- 5 years ago
I solved the problem. There was something wrong with the SD Card image. I tried the factory recovery image & the image from rocketboards.org. They both did not work. We bought 2 boards at the same time and the second one booted up fine. I cloned the image and it worked on the first board. It's unfortunate that you don't a repository of the correct images.
EBERLAZARE_I_Intel
5 years agoHi,
Is this board new? How about the image where did you get the image?
