Sameer-sahu
3 years agoCyclone V E FPGA development kit not responding
Currently, we brought a new Cyclone V E development board kit. On 5th April 2023, we tried to flash a simple blink-led FPGA code into the device by connecting the board through the web UI portal. The...
- 3 years ago
This issue is resolved. Actually I didn't configure JTAG DPI switch perfectly. Thats why JTAG port was not working.
lixy
Contributor
3 years agoHi,
Is the screenshot you showed Programmer 19.1?
Are you able to use a lower version?
Also, I just checked the error information again. The "Unable to scan device chain. On-board programming hardware is disabled." seems to be a common Error information when JTAG chain problem occurs.
Please still firstly check the three possible reasons I listed before: Try to make Blaster tighter to avoid contact problem; Test the voltage of Power rails.
Thanks & Regards,
Xiaoyan
