TerraX
4 years agoCyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
When creating a new Quartus project similar to a demo example, I am trying to place XCVR pins in a blank project and getting an error from the 1.5V PMCL differential pins (HSMC_GXB_RX_p0 and HSMC_GXB...
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
Kshitij_Intel
4 years agoHi,
Tx and Rx are two separate clock domains. Based on two remote transactions there will be CDC problem.
You need to synchronize the data. Reconstruct the data with the valid SDI frame and then re-transmit again.
Add signal tap on relevant signals including clocks.
Thank you
Kshitij Goel
