TerraX
4 years agoCyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
When creating a new Quartus project similar to a demo example, I am trying to place XCVR pins in a blank project and getting an error from the 1.5V PMCL differential pins (HSMC_GXB_RX_p0 and HSMC_GXB...
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
Kshitij_Intel
4 years agoHi Terra,
I cannot use google drive in our PC's.
You should use only SDI II.
SDI v16.1 is very old.
Here, You need to do "Generate transceiver only". Protocol blocks depends on your design requirement and I don't think you need it now.
In the project options, you can archive the project and send it to me.
Thank you
Kshitij Goel
