Cyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
Here is the .qsf file:
# Quartus Prime
# Version 16.1.0 Build 196 10/24/2016 SJ Lite Edition
# Date created = 11:58:04 July 18, 2022
# Notes:
# 1) The default values for assignments are stored in the file:
# CPL_Loopback_1_assignment_defaults.qdf
# If this file doesn't exist, see file:
# assignment_defaults.qdf
# 2) Altera recommends that you do not modify this file. This
# file is updated automatically by the Quartus Prime software
# and any changes you make may be lost or overwritten.
set_global_assignment -name FAMILY "Cyclone V"
set_global_assignment -name DEVICE 5CGXFC5C6F27C7
set_global_assignment -name TOP_LEVEL_ENTITY C5G_HSMC_XCVR_LOOPBACK_TEST
set_global_assignment -name ORIGINAL_QUARTUS_VERSION 16.1.0
set_global_assignment -name PROJECT_CREATION_TIME_DATE "11:58:04 JULY 18, 2022"
set_global_assignment -name LAST_QUARTUS_VERSION "16.1.0 Lite Edition"
set_global_assignment -name PROJECT_OUTPUT_DIRECTORY output_files
set_global_assignment -name ERROR_CHECK_FREQUENCY_DIVISOR 256
set_global_assignment -name VERILOG_FILE V/C5G_HSMC_XCVR_LOOPBACK_TEST.v
set_global_assignment -name MIN_CORE_JUNCTION_TEMP 0
set_global_assignment -name MAX_CORE_JUNCTION_TEMP 85
set_global_assignment -name POWER_PRESET_COOLING_SOLUTION "23 MM HEAT SINK WITH 200 LFPM AIRFLOW"
set_global_assignment -name POWER_BOARD_THERMAL_MODEL "NONE (CONSERVATIVE)"
set_global_assignment -name PARTITION_NETLIST_TYPE SOURCE -section_id Top
set_global_assignment -name PARTITION_FITTER_PRESERVATION_LEVEL PLACEMENT_AND_ROUTING -section_id Top
set_global_assignment -name PARTITION_COLOR 16764057 -section_id Top
set_location_assignment PIN_R20 -to CLOCK_50_B5B
set_location_assignment PIN_N20 -to CLOCK_50_B6A
set_location_assignment PIN_H12 -to CLOCK_50_B7A
set_location_assignment PIN_M10 -to CLOCK_50_B8A
set_location_assignment PIN_U12 -to CLOCK_125_p
set_location_assignment PIN_AB24 -to CPU_RESET_n
set_instance_assignment -name IO_STANDARD LVDS -to CLOCK_125_p
set_location_assignment PIN_V12 -to "CLOCK_125_p(n)"
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to CLOCK_50_B5B
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to CLOCK_50_B6A
set_instance_assignment -name IO_STANDARD "2.5 V" -to CLOCK_50_B7A
set_instance_assignment -name IO_STANDARD "2.5 V" -to CLOCK_50_B8A
set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to CPU_RESET_n
set_location_assignment PIN_V19 -to HEX0[0]
set_location_assignment PIN_V18 -to HEX0[1]
set_location_assignment PIN_V17 -to HEX0[2]
set_location_assignment PIN_W18 -to HEX0[3]
set_location_assignment PIN_Y20 -to HEX0[4]
set_location_assignment PIN_Y19 -to HEX0[5]
set_location_assignment PIN_Y18 -to HEX0[6]
set_location_assignment PIN_AA18 -to HEX1[0]
set_location_assignment PIN_AD26 -to HEX1[1]
set_location_assignment PIN_AB19 -to HEX1[2]
set_location_assignment PIN_AE26 -to HEX1[3]
set_location_assignment PIN_AE25 -to HEX1[4]
set_location_assignment PIN_AC19 -to HEX1[5]
set_location_assignment PIN_AF24 -to HEX1[6]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX0[0]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX0[1]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX0[2]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX0[3]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX0[4]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX0[5]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX0[6]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX1[0]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX1[1]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX1[2]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX1[3]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX1[4]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX1[5]
set_instance_assignment -name IO_STANDARD "1.2 V" -to HEX1[6]
set_location_assignment PIN_AD2 -to HSMC_GXB_RX_p[0]
set_location_assignment PIN_AE4 -to HSMC_GXB_TX_p[0]
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to HSMC_GXB_RX_p[0]
set_location_assignment PIN_AD1 -to "HSMC_GXB_RX_p[0](n)"
set_instance_assignment -name IO_STANDARD "1.5-V PCML" -to HSMC_GXB_TX_p[0]
set_location_assignment PIN_AE3 -to "HSMC_GXB_TX_p[0](n)"
set_location_assignment PIN_H9 -to LEDG[7]
set_location_assignment PIN_H8 -to LEDG[6]
set_location_assignment PIN_B6 -to LEDG[5]
set_location_assignment PIN_A5 -to LEDG[4]
set_location_assignment PIN_E9 -to LEDG[3]
set_location_assignment PIN_D8 -to LEDG[2]
set_location_assignment PIN_K6 -to LEDG[1]
set_location_assignment PIN_L7 -to LEDG[0]
set_location_assignment PIN_J10 -to LEDR[9]
set_location_assignment PIN_H7 -to LEDR[8]
set_location_assignment PIN_K8 -to LEDR[7]
set_location_assignment PIN_K10 -to LEDR[6]
set_location_assignment PIN_J7 -to LEDR[5]
set_location_assignment PIN_J8 -to LEDR[4]
set_location_assignment PIN_G7 -to LEDR[3]
set_location_assignment PIN_G6 -to LEDR[2]
set_location_assignment PIN_F6 -to LEDR[1]
set_location_assignment PIN_F7 -to LEDR[0]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[7]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[6]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[5]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[4]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[3]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[2]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[1]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDG[0]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[9]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[8]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[7]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[6]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[5]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[4]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[3]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[2]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[1]
set_instance_assignment -name IO_STANDARD "2.5 V" -to LEDR[0]
set_location_assignment PIN_C20 -to HSMC_EQBypass_1
set_location_assignment PIN_B19 -to HSMC_EQBypass_2
set_location_assignment PIN_B12 -to HSMC_SDI_CLK_Sel
set_location_assignment PIN_B10 -to HSMC_SDI_Rate_Sel_1
set_location_assignment PIN_A11 -to HSMC_SDI_Rate_Sel_2
set_location_assignment PIN_A13 -to HSMC_SDI_XTAL_Sel
set_instance_assignment -name IO_STANDARD "2.5 V" -to HSMC_EQBypass_1
set_instance_assignment -name IO_STANDARD "2.5 V" -to HSMC_EQBypass_2
set_location_assignment PIN_A17 -to HSMC_CLKOUT_p[2]
set_instance_assignment -name IO_STANDARD "2.5 V" -to HSMC_CLKOUT_p[2]
set_global_assignment -name TIMEQUEST_MULTICORNER_ANALYSIS ON
set_global_assignment -name NUM_PARALLEL_PROCESSORS ALL
set_global_assignment -name SMART_RECOMPILE ON
set_instance_assignment -name IO_STANDARD "2.5 V" -to HSMC_SDI_XTAL_Sel
set_instance_assignment -name IO_STANDARD "2.5 V" -to HSMC_SDI_Rate_Sel_2
set_instance_assignment -name IO_STANDARD "2.5 V" -to HSMC_SDI_Rate_Sel_1
set_instance_assignment -name IO_STANDARD "2.5 V" -to HSMC_SDI_CLK_Sel
set_global_assignment -name QIP_FILE SDI_v16_t.qip
set_global_assignment -name QIP_FILE PLL_XCVR.qip
set_global_assignment -name SIP_FILE PLL_XCVR.sip
set_global_assignment -name IP_SEARCH_PATHS "c:\\projects\\chilipepperlabs\\dev boards\\cyclone 5 gx starter kit\\cpl_hdl_16_1\\sdi-library;c:\\projects\\chilipepperlabs\\dev boards\\cyclone 5 gx starter kit\\cpl_hdl_16_1"
set_instance_assignment -name PARTITION_HIERARCHY root_partition -to | -section_id Top
