Cyclone V - Differential Pair Pin Assignment 1.5V PCML fitter error
- 4 years ago
Hi Terra,
I have told you earlier, you cannot directly connect, Please design custom logic to reconstruct the word. First correct your design then try to compile.
Thank you
Kshitij Goel
My project is empty except for pin locations, which file extensions are what you want to see?
I am trying to figure out what is the minimum I need to connect the pins together.
My goal is just to make a straight through connection between these pins:
INPUT: HSMC_GXB_RX[0] on PIN_AD2 (HD-SDI in)
OUTPUT: HSMC_GXB_TX[0] on PIN_AE4 (HD-SDI out)
Any suggestions would be very helpful. I am using the Terasic Developement board C5G with an SDI mezzanine breakout board so I can't really move the pins around too much.
The signal that I am passing through is HD-SDI. (It is NOT a dual link)
