17 years ago
Cyclone III / Bitec Video Dev Kit
Hi
I got the Cyclone III dev kit a few days ago together with the Bitec dvi in/out and the quad comp board.
First I tried to run the 71 vesion of Quartus II and Nios II on Vista ...no luck
I then downloaded the ver 81 of both and still had problems on Vista then I installed on Xp and it seems to work :-)
I can do the Counter demo in QuartusII, great
I can do the Hello World in Nios II, great
Then I try to do the Moasic for 4xcomp with the Bitec code and I can build all.
But when I do right click on "hsmc_quad_video_demo and select run as Niro II hardware it do build a bit more and try to download with this result
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Initializing CPU cache (if present)
OK
Downloading 00000000 ( 0%)
Downloaded 9KB in 0.1s
Verifying 00000000 ( 0%)
Verify failed between address 0x0 and 0x200F
Leaving target processor paused
I would be very happy if someone have a good hint to get pass this point
Thank you
Wiljan
    i think you will have to buffer more than a line at a time to rotate the video.
