Cyclone 10 LP nConfig problem
I have a project where I have connected the nConfig pin of the Cyclone 10 LP thru FET (drain pin) with PU.
the gate of the FET is connected to GPIO of bank 8 (3.3V), and the source connected to GND.
On power up the state of the GPIO is as desined in the FAB and it become high - so the FET is saturated and the nConfig pin is driven low.
this issue generate a loop where the FPGA can not finish the init proccess and I have to remove the serial resistor from the gate of the FET to let the FPGA finish the init proccess.
this connection was on my previous design with Cyclone 3 and it worked well.
Is there any reason why it is happaning?
Can I chnage the state of the GPIO before the init proccess finish? (there is a way to set GPIOs as weak Pull-Up but no weak Pull-Down)
thanks for the help
- FvM
the usual solution is to connect a pull-down overriding weak pull-up, value depending on FET Vth e.g. 470R to 1k.- omriL
Hi FvM,
Thanks for the help,
will try and share the resualts,
BR,
Omri
- FakhrulA_altera
Hi OmriL,
FvM is correct. You can also set the I/O to weak pull-up during configuration.
Fakhrul
- FakhrulA_altera
As we do not receive any response from you to the previous notification that we provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
