AJone5
8 years agoCyclone 10 LP Evaluation kit not booting NIOS from EPCQ flash
I have a Cyclone10 LP evaluation kit that I'm using to try to develop a small test program. I can't seem to get the NIOS to boot successfully from the EPCQ128A flash although the FPGA is configuring....
AnandRaj_S_Intel
8 years agoHi,
While generating .jic use correct .hex file(EPCQ one)
Try with the below project file attached.
Anand Raj Shankar
- MMacg6 years ago
Hi Anand,
the example design you posted for the Cyclone 10 LP board has been very helpful to make some headway booting from EPCQ. However, I was wondering if it would be possible for you to modify your example design to work with execute in place on the EPCQ device? I have tried modifying the example myself as per the AN-736(Nios execute in place) but unfortunately I am not managing to get the nios to come up correctly.
Cheers
MIke
