OBenE's avatar
OBenE
7 years ago
Cyclone 10 gx sdi audio
is there any way to use the audio embeded ip on the cyclone 10 gx?
  • CheepinC_altera's avatar
    CheepinC_altera
    Hi, As I understand it, you are inquiring about using SDI audio embed IP in C10GX devices. For your information, audio IP is not supported in 10 series devices. Therefore, you would not be able to use the audio IP in C10GX devices. Sorry for the inconvenience.
  • OBenE's avatar
    OBenE
    as i can see on the document, on the 24.7.19 intel added the support for arria 10.
    can anyone know if intel will add the cyclone 10 gx support?
    thank you
    omer.
      CheepinC_altera
      Hi, Yes, your understanding is correct. Recently Factory releases SDI Audio IP for A10 devices. However, as per my understanding, I am not aware of any plan to support for C10 devices currently. Sorry for the inconvenience. Best regards, Chee Pin
  • ZivN's avatar
    ZivN
    as i can see on the document, on the 21.06.22 intel added the support for Stratix® 10.
    thank you
    ziv.
